[B]'00 Cluster Lights Go Out Bad Connection
Old Feb 17, 2013 | 06:40 PM
bkingarn's Avatar
Default [B]'00 Cluster Lights Go Out Bad Connection
Hey Guys,
I've read a lot of threads about dash cluster backlights not working due to radios or turning off/on headlights. I have a different problem with my '00 EX Accord that involves the connector at the top left of the cluster panel. I opened the dash covers and rolled the cluter panel out so I could see the connector. When I took the connector off and clean it with Q-tips and alcohol and put it back on I could get the cluster backlights to work but just a little wiggling of the connector plug and they would go back off. I kept cleaning and reseating the connector and the lights stayed on better. I put the dash back together and the backlights worked for a week or two and then wouldn't come back on again. I had read somewhere on the internet that you could put a jumper wire between two of the wires on the connector and it was a work around for this problem.
Any of you guys familiar or head of this jumper? I don't want to have to change out the instrument cluster and lose my original odomoter.
Old Feb 18, 2013 | 06:04 PM
I think, the jumper is for the multiplex....meaning you never have lights unless the jumper is in place.
I don't have a link saved but I know I have seen this "jump" posted on here more than once.
Neptun3
Mar 11, 2017 09:13 AM
SPBAV6
Sep 27, 2013 09:47 AM
giulio76
Dec 29, 2012 11:16 AM
byrothapyro
Oct 10, 2010 08:11 PM
marbro
May 20, 2006 10:13 PM
