[Deleted]
Old Nov 26, 2007 | 11:41 AM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Nov 26, 2007 | 11:52 AM
nafango2's Avatar
Default RE: power steering fluid change
what i did is take a milk carton and cut it in half, then take the lower half and put it below the reserviour. i then disconnected one of the hoses and drained the reservour into the milk carton. then i put the return hose into the carton and held my finger over the return hose nipple (so the fluid doesnt leak out again) and filled the reservour. I had a friend start up the car, and poured new fluid into the reservour as it drained, and also watched the color of the fluid draining into the carton. When the new fluid started coming out of the hose i had my friend shut off the car. Then all the old fluid was "flushed out" and replaced with new fluid. I reconnected the return hose, topped off the reservour, and started it up to check for leaks.
Old Nov 26, 2007 | 12:00 PM
Note, the reservoir has an inlet screen/filter in it's base. I don't believe it's serviceable but you might remove and flush w/ solvents, and dry. Otherwise a new reservoir is necessary to avoid new fluid looking like old fluid shortly.
Old Nov 26, 2007 | 12:05 PM
nafango2's Avatar
also remember to put loads of paper/shop towels on top of the alt and A/C compressor when your doing this! power steering fluid ruins alternators.
Old Nov 26, 2007 | 08:39 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Nov 27, 2007 | 12:08 AM
Depending on what year Accord, you may have better luck opening a hose down low leading out front to the PS fluid cooler.
Deleted User
May 11, 2006 02:08 AM
Deleted User
Nov 15, 2005 06:26 PM
Deleted User
May 9, 2005 02:16 AM
Deleted User
May 4, 2005 06:13 PM
Deleted User
Mar 23, 2005 01:48 PM
