'00 accord pinging under partial throttle
Old Dec 18, 2011 | 04:07 PM
mitbrown's Avatar
Default '00 accord pinging under partial throttle
Ok, so I have a 2000 Accord LX 2.3l, F23a1. I can't figure why it's pinging. It starts pinging at like 40% throttle, but goes away if I push the pedal a bit further. The issue is only present below 3000 rpm. Any ideas why it's pinging? I have new Ngk plugs, and am running 91 octane ethanol free gas. Please help!
Old Dec 19, 2011 | 12:35 AM
Is the check engine light turning on while driving? Most auto parts stores will scan the codes as a free service. Post any codes on here. They start with the letter P and have four numbers, like P1234.
Old Dec 19, 2011 | 01:55 PM
mitbrown's Avatar
Check engine light is on, I don't remember the exact code number but it
Reads 'catalyst system efficiency below normal'. It came on after I had a test pipe installed.
Old Dec 19, 2011 | 04:06 PM
Get the codes checked again. You may have a new code that is appearing.
Old Dec 19, 2011 | 04:37 PM
mitbrown's Avatar
Ok, I'll pull the codes again when I get off work. But the problem has existed before I ever had the cat removed. I was actually hoping the cat was clogged and the test pipe would solve it, but the pinging is still there.
Old Dec 19, 2011 | 05:05 PM
Stop at an AutoZone...they will check it for you for Free...
Old Dec 19, 2011 | 05:55 PM
posativJ311's Avatar
catalyst system efficiency below normal can also mean an o2 sensor.
Old Dec 19, 2011 | 07:39 PM
mitbrown's Avatar
Well I have a plx kiwi Bluetooth adapter so I can pull up the
trouble codes on my phone.
I'll go get new o2 sensors and report back I guess.
What's a good brand o2 sensor for this car?
Old Dec 20, 2011 | 05:44 PM
Is this test pipe still installed?
Old Dec 20, 2011 | 07:32 PM
mitbrown's Avatar
Yes the test pipe is still in place.
Why do you ask?
Would I be better off getting a catalytic converter put back on?
