'01 Accord Low Fuel Light Inoperable
Old Apr 27, 2005 | 12:08 PM
Patrick's Avatar
Default RE: '01 Accord Low Fuel Light Inoperable
i mean, something like that would obviously be best case scenario...with something like a sending unit, while not that severe, being worst case,i would think.
Old Apr 27, 2005 | 09:36 PM
Evlampius's Avatar
make sure you know what you're doing ok
i mean - sending the inverse electrical may even worsen the situation - so be carefull
if the gage works fine - i would think the led is burnt ..
anyway - fill up the tank and drive it assumably till you know for sure you're close to an end - I hope you know you're MPG milage ( everyone should) if you're getting wrong readings that would indicate the faulty sender . Infact - i have a problem with my sender - i think all 94-97 affected with that problem - just dont have the extra 100$ to spend on a new one - my tripo meter works just fine
Old Apr 27, 2005 | 10:30 PM
Patrick's Avatar
i wouldnt worry about something as small as that either...but if you really want to look into it..make sure the battery is disconnected..
Old Apr 28, 2005 | 12:38 AM
Evlampius's Avatar
ORIGINAL: Patrick
and dont forget about Car Stereo Anti Theft - get a code
Old Apr 28, 2005 | 11:50 AM
Patrick's Avatar
hmmm...i did forget about that...excellent point.
Old Apr 29, 2005 | 04:27 PM
6thgen's Avatar
It's a tad common for your model.
Old Apr 29, 2005 | 04:58 PM
  #17
Patrick's Avatar
the non-functional fual gauge is? do you knwo why? is it a sending unit issue or the gauge itself?
Old Apr 29, 2005 | 05:18 PM
  #18
6thgen's Avatar
Not sure the exact problem, let me do some research and I'll get back to you.
Old May 8, 2005 | 11:25 AM
  #19
Evlampius's Avatar
ORIGINAL: Patrick
yes 94-97 is a common problem with a sender , the sender resistors fail after a short time, I'm not sure if there was a recall on that , corrective action is to replace the Sending unit
however if you DO decide to replace the sending unit - buy HONDA ORIGINAL ONLY!! do not get aftermarket part.
also dont forget if you pull the sender out of the gas tank the gasket has to be replaced too. doesn't matter if you change the sender or not.
~~~~~~~~~~~~~~~ Anyway back to the post~~~~~~~~~~~~`
on 2001 hondas the fuel gauge and the sender are the seperate system from the low level light indicator.
the low fuel level is controlled by a thermister within the fuel tank. If you want I will give you some info on how this thermister opperates and how to check it - but unless you care I will not even bother since noone watching this post anyway... []
Old Nov 8, 2005 | 10:24 PM
  #20
FlyLow's Avatar
I want to know Elvamp, I was having same problem before on my '99, then it started working again just like that. Yet I would still like to know how that works, is it even same as in '01? [sm=redx.gif]
