01 Accord Shaking and shuddering
Old Feb 10, 2008 | 10:17 PM
HondatechAV6's Avatar
Default RE: 01 Accord Shaking and shuddering
if you are going to remove the pump to replace the screen you might as well replace the pump. the screen isn't very great, just enough.
Old Feb 12, 2008 | 01:01 PM
dgem
The check engine light came on yesterday and I had multiple misfire codes. I have brand new plugs, wires, distributor cap, rotor button, and 02 sensor. It is still shaking and shuddering, and will not accelerate when gas is depressed. Any ideas?
Old Feb 13, 2008 | 01:06 PM
dgem
bump bump
Old Feb 13, 2008 | 02:33 PM
klrspz's Avatar
what kind of plugs? NGK's are the only ones to be used.
Old Feb 13, 2008 | 08:01 PM
jcocker03's Avatar
I had a 91 oldsmobile that hadsimilar symptoms. There was a magnet on the crankshaft that the crankshaft position sensor read, and that magnet flew out,I foundthe piecesofitin the oil pan.
When the magnet came out, the engine ran on default settings, and would hesitate when you gave her gas, had trouble in the high rpms, and suffered an all around power loss. I replaced the magnet, and she ran great.
Don't know if this helps.
Old Feb 15, 2008 | 12:06 AM
dgem
Finally the problem is solved. I replaced all four injectors and she is as good as new.
rpunya
Nov 1, 2014 05:12 AM
thedavis4
Jun 5, 2010 11:32 AM
heardaneaglecry
Sep 29, 2009 07:17 AM
Lulu EXV6
Oct 24, 2008 11:28 PM
