01 accord turn signal replacement
My turn signal is broke, everything works but high beams,and that's just cause lever won't go back far enough.I just need to replace lever I think,somethings broke..
The entire stalk and switch assy are replaced as a unit. Numerous used parts available on ebay at reasonable prices. Here's one:
http://www.ebay.com/itm/SM1125-Turn-...02ff8b&vxp=mtr
Look under Youtube for videos on replacing the ignition switch assy. This requires removal of upper/lower steering column shells (very obvious though).
Once shells are removed (3-4 screws), some additional screws release the turn signal switch assy. Plug in new switch and replace shells.
Ntegra
Oct 9, 2006 12:37 AM
