01 accord won't start after heater core install
It's about 1.5 inches long, by a 1/2 inch wide, with 2 blades pointing down. I believe these might be dealer only parts.
I'd pull it out and verify it's blown first.
Everything seems to be working and reading fine but can't hear the fuel pump kick on when I turn the key on so I replace the fuel pump relay and it's still not kicking on. I'm thinking maybe the fuel pump is bad cause it's getting spark and everything just doesn't seem to be getting gas. I figured if the fuel pump was bad then it would still kick on regardless
Note; if the engine doesn't start, then you might not be getting power to the ignition coil or distributor, or coil packs (don't know which you have).
A little update came to the conclusion after doing research and the problem has to be either something with the key, ecu, or key immobilizer maybe. Symptoms are the car will not turn on if the green key immobilizer light won't come on. Every light comes on when in the on position but the check engine light and the green key immobilizer light. I've replaced the main relay fuse so that didn't work. Any advice is welcomed and took to the dealership today so we'll see maybe tomorrow or this week what the problem is
