02 Accord, Heater fan only works on High?
Old Dec 27, 2014 | 06:38 PM
JOE.G's Avatar
Default 02 Accord, Heater fan only works on High?
Hi, Yesterday my Heater fan only worked on high and it also didn't seem to change between outside air and inside air, Tonite it started to work again on all levels and seemed to switch between inside and outside air, Is there some sort of relay or fuse for this? Any ideas on what to check and where? Thanks
Old Dec 27, 2014 | 06:48 PM
Probably a faulty blower motor resistor. When the heater fan switch is in position 4, the entire resistor is bypassed and the blower motor runs at the highest speed. At lower heater fan switch positions, the ground for the blower motor goes through segments of the resistor.
Old Dec 28, 2014 | 01:39 PM
JOE.G's Avatar
Ok, How do I replace this? Where is it located?
Any idea on a part number not sure exactly what to search for thanks.
Old Dec 28, 2014 | 03:33 PM
The blower resistor is attached to the left-underside of the blower motor assembly (blower under passenger side dash).
To replace it, you disconnect electrical connector and then unscrew two phillips screws.
At Honda dealer sites, it is under the heater blower section. Accords with manual A/C uses a blower motor resistor, whereas Accords with Climate Control (semi and fully auto) uses a blower motor transistor. Sounds like your Accord is manual A/C, so it would use the blower moor resistor.
There are aftermarket units available that you can check for at your local parts stores.
Old Dec 28, 2014 | 04:00 PM
JOE.G's Avatar
Thanks, How would I know if it is Auto or Manual?
This is the part number I found does it look right?
Honda Part Number: 79330-S84-A01
Old Dec 28, 2014 | 04:17 PM
Climate control has an "Auto" button, see image.
Manual A/C does not have that button. That is just one of the things.
That looks to be the correct Honda part number for the blower motor resistor.
Attached Thumbnails 02 Accord, Heater fan only works on High?-climate-control.jpg
Old Dec 28, 2014 | 07:26 PM
JOE.G's Avatar
Ok I dont have the auto one thanks
Old Dec 30, 2014 | 01:38 PM
If you haven't change the cabin filter (e.g. dust/pollen filter) in a while, you may want to replace it.
Old Dec 31, 2014 | 07:04 AM
JOE.G's Avatar
Yeah I have the filters, I just need to do it, My Shop is filled with winter projects so Ill have to change the honda filters in the spring as it is pretty cold out right now. Do you have a good write up on the steps to change them?
Old Dec 31, 2014 | 06:04 PM
This video shows the replacement. It takes a little time.
