'03 Accord LX-Maintenance Light
Old Jun 23, 2006 | 08:33 PM
shrek daddy
Default '03 Accord LX-Maintenance Light
Howdy-
At around 39K miles, the maint. light on my '03 Accord LX (4cyl) started flashing 10X at every start up, then would turn off. Now at 40K miles, the light stays on. I called the dealership and of course they gave me the canned answer that I need to bring the vehicle in for 10K service and reset the coding.
Is there any way that I can reset the light myself? On the older Hondas, thought you could hold in the odometer **** while cranking the ignition. This method doesn't seem to work on my vehicle.
Feedback is appreciated.
Old Jun 23, 2006 | 08:56 PM
sir_nasty's Avatar
Default RE: '03 Accord LX-Maintenance Light
I believe that unless the changed it there is a slot that your key fits into just to the left of the light that resembles a recessed odometer reset switch... just push it in and hold it down for liek 15 seconds (your key fits right in to hold it down...)
Old Jun 23, 2006 | 10:44 PM
deserthonda's Avatar
what Sir said is for the oldr cars,,
on the 03,, hold down the select/reset button on the rt lower part of the instrument cluster, turn ignit key on, keep holding button for agout 15-20 seconds , light will clear ..
Old Jun 26, 2006 | 11:30 AM
shrek daddy
Thanks for the advice...will give it a try this evening.
Old Jun 26, 2006 | 01:05 PM
YeuEmMaiMai's Avatar
the 6th gen and 7th gen cars use the same procedure. The 5th gen and earlier (pre 1998) use the older insert the key method.
Old Jun 28, 2006 | 11:32 AM
shrek daddy
Tried this a coupla nights ago & it worked just fine...no more irritating dummy light to blind me. Thanks for your help!!
Reboticon
Aug 24, 2010 06:50 AM
ndp125
Feb 28, 2008 02:50 PM
Khonsaiho
Sep 6, 2007 10:39 PM
Daud
Mar 27, 2007 01:52 AM
hotrod01
Nov 11, 2005 01:28 AM
