03 accord v6 stuck in park & dash lights not working
Old Nov 8, 2012 | 03:31 AM
dantheman86's Avatar
Default 03 accord v6 stuck in park & dash lights not working
Hello, i tried searching for this combination but no luck. I have a 2003 Honda Accord v6 with auto transmission. Today my vehicle became stuck in park, when the ignition is on the dashlights do not turn on, the brake lights and lights work, the turn signals do not work. I checked all the fuses in the drivers side panel and inside the hood, all good. Also the windshield wipers do not work. Does anyone know what is wrong?
Old Nov 8, 2012 | 10:21 AM
Check the battery and battery cable connections.
Old Nov 8, 2012 | 11:50 AM
Try repeating use of ignition switch to see if problem goes away. If yes, a new ignition switch is needed soon.
Old Nov 8, 2012 | 06:33 PM
Just me here, please double check the underdash #21 7.5 amp fuse......it is common for everything you have listed that is not working.......are the back up/reverse lights working?
Do I ever say I hate electrical issues
Old Nov 8, 2012 | 09:16 PM
Looks like there's more to this story:
"http://honda-tech.com/showpost.php?p=48081794&postcount=1"
Old Nov 9, 2012 | 06:11 PM
I don't like it when they do that to us
Oh well, I'll stick with the fact that when the op "jumped" the wires it blew the fuse . If they would
I did have to ask them over there if the backup/reverse lights work.....couldn't help it
Old Nov 12, 2012 | 06:18 PM
happy birthday poorman212 "two days late", anyways for some reason it was a 7.5 fuse, the LG meter fuse. i replaced it and lights came back on as well as removing the stuck in park problem. I got a new master switch. passegers side still does not work. It sucked the other day, clicker button for key still does not work. But the drivers window works. I will probably have to replace the passengers switch. It sucked the other day, i had to drive at night on the highway when it was less than 40 degrees. Then i got smart and used plastic as a shield for the window.
Old Nov 12, 2012 | 09:31 PM
Thank you for coming back with an update.
We can help with the testing of the window....but that is up to you.
Old Oct 6, 2014 | 02:15 PM
I replaced both window switches the drivers window regular and the multiplex control unit under the drivers dash. I reprogrammed ny key. I can unlock the trunk with it. When I click lock and unlock I hear clicking sounds from under the fuse box in the engine area. I noticed wear the multiplex control unit is their is a single purple wire dangling. We're does it go? Also how do I get the passengers side window to roll down? It just clicks when I try winding it down thanks.
csh217
Apr 30, 2013 09:03 PM
Uberpippi
Feb 1, 2013 10:09 PM
AJKing
Jul 11, 2011 08:38 PM
neverendingmods
May 28, 2009 12:16 PM
kangas
Mar 17, 2008 10:04 AM
