'03 EX-L Intermittent CEL p2195, p0171
Old May 25, 2014 | 07:57 AM
Look for a wire in the harness to be gnawed (sp?) through. I had this problem w/ knock sensor on my MDX. This might explain 2195.
Note wire could be damaged anywhere between sensor and ECM. Some wires are more attractive to rodents than others due to insulation components (soy based plastics).
Old May 25, 2014 | 08:57 AM
If it was a rodent that made a nest from the hood insulation or something else, then inspect along the engine wire harness wiring for the AF ratio sensor (attach are images of the connectors and routing for the sensor in the engine compartment). In the wire routing diagram, #8 is connector C201 and #26 is the connector for the AF sensor.
Honda sells rodent repellent tape.
Attached Thumbnails '03 EX-L Intermittent CEL p2195, p0171-af-sensor-connector.jpg   '03 EX-L Intermittent CEL p2195, p0171-connector-c201.jpg   '03 EX-L Intermittent CEL p2195, p0171-engine-wire-harness-routing.jpg   '03 EX-L Intermittent CEL p2195, p0171-honda-rodent-tape.jpg
Old May 25, 2014 | 11:17 AM
skyfire322's Avatar
Thanks! I owe you big time!!!!
I'm starting to think it may be possible the little pest could have chewed on a hose, causing a leak, thus throwing the 0171 too.
Old May 25, 2014 | 12:03 PM
I'm not trying to derail this thread by my comment.
O2's/AF Sensors wear out over time - most suppliers give them ~100K miles.
Give everything a good inspection for signs of "chewing" and then go back to where the others were going before I got everything "off track".
Old May 25, 2014 | 12:14 PM
I also agree, if there is no wire damage, it may just the be A/F sensor needing replacement as previously mentioned. My opinion is that if it is the A/F sensor, it may also take care of the other code P0171; as they are both related to a lean condition.
The service manual states in part if codes such as P2195 is indicated at the same time as P0171, to troubleshoot those codes (for example, P2195) first, then recheck for P0171.
Old May 25, 2014 | 12:35 PM
YES - again, sorry I started to get things off track
Old May 25, 2014 | 01:59 PM
  #17
skyfire322's Avatar
It's okay! Better to be safe than sorry.
I checked all of the wiring, and saw no signs of chewing. Just two other small nests. I did notice the A/F sensor was a little slimy, and smelled a bit of ATF. My ATF is a little low, but no signs of drippage or leaks. Next pay period, I'll be replacing that.
Old May 26, 2014 | 07:43 AM
  #18
Please update us as you go.....Thanks
Old May 29, 2014 | 08:02 PM
  #19
skyfire322's Avatar
Do I need that special O2 removal tool, or can I just use an adjustable clamp wrench or crows foot (flare nut) wrench?
Old May 29, 2014 | 08:14 PM
  #20
An O2 sensor wrench and a breaker bar makes it easier. Other wrenches would work, as long as you don't round off the sensor nut and able to get enough leverage on it to loosen it.
The O2 sensor wrench/socket should be 22mm.
