04 Accord Horn Won't Work
My horn will not work anymore. I did have someone break into my car last week. I am not sure how they got in but nothing was damaged and everything else seems to be working properly. I checked the fuse and it is fine (along with the brake lights that are linked to that fuse). I assume the break in is what did it, but not sure how. The alarm lights inside are still flashing when it is set also.
I also got the airbag replacement recall done a month ago at the dealer but the horn was working after that. Just a bit puzzled now. Thanks for any help. |
2 Attachment(s)
Check the wires to the horns. Remove the plastic clips and plastic cover to see the horn wiring and connectors. If wiring is intact, then if you have a voltmeter, check whether there is power (+) on the Blu/Red wire with the horn pressed.
