04 Accord Horn Won't Work
Old Jan 21, 2015 | 12:57 PM
bpdunlv's Avatar
Default 04 Accord Horn Won't Work
My horn will not work anymore. I did have someone break into my car last week. I am not sure how they got in but nothing was damaged and everything else seems to be working properly. I checked the fuse and it is fine (along with the brake lights that are linked to that fuse). I assume the break in is what did it, but not sure how. The alarm lights inside are still flashing when it is set also.
I also got the airbag replacement recall done a month ago at the dealer but the horn was working after that.
Just a bit puzzled now.
Thanks for any help.
Old Jan 21, 2015 | 01:16 PM
Check the wires to the horns. Remove the plastic clips and plastic cover to see the horn wiring and connectors. If wiring is intact, then if you have a voltmeter, check whether there is power (+) on the Blu/Red wire with the horn pressed.
lalblue
Nov 25, 2010 08:06 PM
Pickrng
May 24, 2010 09:16 AM
jshak2
Nov 30, 2009 02:08 PM
sx460
Mar 5, 2009 09:53 AM
aml22001
Mar 28, 2008 07:29 PM
