Sponsored by:
Sponsored by:
04 Accord Horn Won't Work
Old 01-21-2015, 12:57 PM
bpdunlv's Avatar
Default 04 Accord Horn Won't Work
My horn will not work anymore. I did have someone break into my car last week. I am not sure how they got in but nothing was damaged and everything else seems to be working properly. I checked the fuse and it is fine (along with the brake lights that are linked to that fuse). I assume the break in is what did it, but not sure how. The alarm lights inside are still flashing when it is set also.
I also got the airbag replacement recall done a month ago at the dealer but the horn was working after that.
Just a bit puzzled now.
Thanks for any help.
Old 01-21-2015, 01:16 PM
Check the wires to the horns. Remove the plastic clips and plastic cover to see the horn wiring and connectors. If wiring is intact, then if you have a voltmeter, check whether there is power (+) on the Blu/Red wire with the horn pressed.
lalblue
11-25-2010 08:06 PM
Pickrng
05-24-2010 09:16 AM
jshak2
11-30-2009 02:08 PM
sx460
03-05-2009 09:53 AM
aml22001
03-28-2008 07:29 PM
Quick Reply: 04 Accord Horn Won't Work
