horn and cruise control doesn't work.
Old Mar 28, 2008 | 03:25 PM
aml22001
Default horn and cruise control doesn't work.
I have a 1995 Honda Accord LX which I recently had the rack and pinion changed and now the horn and cruise control do not work and the SRS light stays on. I was hoping someone could tell me why that was. I heard it could be the clock spring/cable reel and if that is what it is does anyone know how to change it? Thanks for your help!!!
Old Mar 28, 2008 | 06:38 PM
tcheema's Avatar
Default RE: horn and cruise control doesn't work.
It probably is the clock spring, the same thing happened to my mom's van. You should go back to the mechanic and have him adjust it or look at it, technically he should do it for free.
Old Mar 28, 2008 | 07:29 PM
hondadude's Avatar
When the steering column is taken loose you MUST lock the steering wheel in the center; the clock spring/reel only turns 1 1/2 turns in either direction.
I agree the person that did the rack R&R should be responsible for the replacement of the reel.
cukaracha
Jul 3, 2015 12:55 PM
freemoney
Nov 19, 2010 02:30 PM
fxdwg73
Nov 12, 2010 08:03 PM
MizterKewl
Aug 4, 2010 06:58 PM
MisterBen
Dec 22, 2008 05:01 PM
