Cruise Control Doesn't Work
Old Aug 4, 2010 | 03:43 PM
MizterKewl's Avatar
Question Cruise Control Doesn't Work
I have a 1999 Honda Accord EX Coupe
I got my brake light switch replaced awhile back because my gears wouldn't change. It fixed the problem but now my cruise control doesn't work. I was reading somewhere that it could possibly be that, the switch was installed (maybe) a little loose. I know that the brake light switch also has some kind of connection the the cruise control but i was curious to know if it could be anything else.
Old Aug 4, 2010 | 06:58 PM
I would double check the brake switch, cruise working beofre and the only thing that happened was a replacement switch? Yes they are connected, press the brake and cruise turns off. Sounds like the switch in not completly closing. Don't have the wire diag downloaded but I think you can find a pleace to do so in the faq section.
If ok then comes more testing (fuses, ect.). Which the manuals you download will help you through.
Ralph
Apr 12, 2012 06:03 PM
freemoney
Nov 19, 2010 02:30 PM
fxdwg73
Nov 12, 2010 08:03 PM
MisterBen
Dec 22, 2008 05:01 PM
aml22001
Mar 28, 2008 07:29 PM
