cruise control doesn't work-01 accord
Old Nov 12, 2010 | 04:43 PM
fxdwg73's Avatar
Default cruise control doesn't work-01 accord
just bought an 01 accord bout a week & 1/2 ago, noticed on way home with it the cruise didn't work. have a 92 prelude, and when ever i had a problem- i was always able to find an answer here, so the first thing i did was check this site. my fuses are all good, my switches all work(even the brake pedal), lights all light up, but yet no cruise control. what i did notice, and im pretty sure this is the problem,just dont want to spend $200 to be wrong. there is a crack & a good size piece of plastic missing from the vacuum acuated servo. am i not getting a good vacuum resulting in no c.c. or is it an internally sealed unit & the housing just for looks?
Old Nov 12, 2010 | 06:12 PM
Suggest temporarily patching the actuator w/ tape to see if that fixes the problem. You might be able to come up w/ a permnent patch, or look for a used part (car-part.com).
Old Nov 12, 2010 | 06:25 PM
fxdwg73's Avatar
i tried tapeing it, seemed like it wanted to work but stopped after a few seconds. im not gonna lie,it might not of been the best tape job. thank you though
Old Nov 12, 2010 | 06:27 PM
fxdwg73's Avatar
i might get in there & try t tape it better now that i know im not the only one thinking that way
Old Nov 12, 2010 | 07:27 PM
I'm doubtful tape will be a permanent solution. I've had good results using J&B Weld epoxy and rip-stop nylon to make patches and reinforcement of plastic pieces. Roughen the plastic surface w/ sand paper before starting.
Not worth a lot of effort as a used part is only $20-$30.
http://www.car-part.com/cgi-bin/sear...ey=&userPage=2
Old Nov 12, 2010 | 08:03 PM
g22cd5's Avatar
Supper Moderator
since you have one of the mods answering your questions I won’t delete your thread this time I will move it. Next time read the rules and post in the correct area of the forum.
Thanx you
Ryan
Ralph
Apr 12, 2012 06:03 PM
freemoney
Nov 19, 2010 02:30 PM
MizterKewl
Aug 4, 2010 06:58 PM
MisterBen
Dec 22, 2008 05:01 PM
aml22001
Mar 28, 2008 07:29 PM
