Iginition relay or what!?!?!
Old Nov 10, 2010 | 11:06 PM
gobabygo95's Avatar
Default Iginition relay or what!?!?!
I have a 95 accord ex 2.2 vtec 5 speed. when you go to start it, it starts than immediatly dies. but if you hold key to start it stays started until you let key go back to on, than it dies. ignition coil was bad, replaced that still does it. maybe ignition relay under dash? or maybe contact isnt staying inside ignition? PLEASE HELP!!!
Old Nov 10, 2010 | 11:58 PM
Sounds like the ignition switch.
techauto dot awardspact dot com/ignitionswitch.html
Old Nov 11, 2010 | 07:37 AM
x2 for a bad ignition switch.
The story about staying running while you hold the key makes it almost certain.
Old Nov 12, 2010 | 10:39 PM
gobabygo95's Avatar
replace it? or is there any tricks to make it work??
Old Nov 12, 2010 | 10:42 PM
Replace it. It is the electrical switch you would be replacing. In the link, look for portion of the Technical Service Bulletin (TSB) applicable to your 5th gen Accord.
Old Nov 12, 2010 | 10:57 PM
This is the part:
fixmeup12
May 30, 2013 12:32 PM
greg05
Aug 31, 2009 05:32 PM
quietgiant
Apr 1, 2006 01:05 PM
fivespeedsport
Dec 29, 2005 04:10 PM
Cleric
Dec 26, 2005 09:09 PM
