SRS Airbag Light / Horn & Cruise Don't Work
Old Jun 16, 2007 | 11:11 PM
sx460
Default SRS Airbag Light / Horn & Cruise Don't Work
Hello there,
Today I picked up my first Accord. It's a 1996 Accord LX, 2.2L SOHC, 4 door, black, auto with 133K miles. It's in really good shape however it has a few quirks. I bought it from a cousin who I really trust. They said that the only problems with it is a slight leak that the shop noticed from the AC and also that it needed new tires.
However, I failed to notice that the cruise doesn't work, the SRS light stays on (red), and I can't use the horn. It sat for 6 months because they never got around to selling it. The clock is displaying the wrong time so I'm guessing while it sat it ran out of juice and they had to jump start it. So they probably never noticed that the SRS light is on and that the cruise and horn stopped working.
I'm guessing that those things are all powered on the same circuit? It too dark out right now to check if it has a blown fuse but I figured that I would ask the forum as soon as possible before digging around.
Any thoughts on what I should check? Thanks
Old Jun 17, 2007 | 10:38 AM
hondadude's Avatar
Default RE: SRS Airbag Light / Horn & Cruise Don't Work
The SRS control unit will store a code for low voltage, and there is a reset method, but the other symptoms of the cruise and horn problem could lead to a problem in the 'reel' in the steering column.
It is a sliding contact set up, that allows the electrical contacts to work when the steering wheel is turned.
SRS reset link;
http://img337.imageshack.us/img337/5246/srsresetbg6.gif
And tests to check the cruise control buttons;
http://img339.imageshack.us/img339/6...isetestcr1.gif
At 133k miles you need to be sure the Timing belt has been changed
Old Jun 17, 2007 | 12:19 PM
deserthonda's Avatar
I have to agree with Dude ..sounds like there is an issue with the cable reel.. it also would make the srs lite come on .besides the other 2 issues ,
Old Jun 17, 2007 | 07:38 PM
sx460
Thanks for the input. Is there anything else simple I could try like blown fuses? If it is the cable reel, is it hard to replace change? Is it something that I should tackle myself (if I took it somewhere how much do you think it would cost). Thanks!
Old Jun 18, 2007 | 06:10 PM
sx460
bump
Old Jun 20, 2007 | 02:02 PM
sx460
I'm thinking of doing this myself. Are cable reels and clock springs the same thing with just different names or are they two different things? I'm having trouble finding a cable reel for a 1996 Accord LX 2.2L online. However I've been able to find a clock spring. They both look about the same in the pictures so I'm assuming it's the same thing with just a different name.
Old Mar 5, 2009 | 02:02 AM
asift2
Default same problem
Hello,
I am having same problem with my accord 96 v4 first srs light came on then horn went and then after cruise control stop working i dont know what to do checked all the fuses nothing blown .any suggestions on what might be the problem.
Old Mar 5, 2009 | 09:53 AM
wish234's Avatar
Originally Posted by asift2
Hello,
try this
http://tor.in.honda.com/Rjanisis/pub...096S23350A.pdf
i have the same issue with my 97 accord lx. I havnt looked into the cable reel yet but plan on doing it this weekend. I just dont know how to tell if its bad other then replacing it and im not sure where to buy one at
cukaracha
Jul 3, 2015 12:55 PM
wings
Jan 19, 2011 09:06 AM
Rob_KCMO
Apr 18, 2010 12:05 AM
jshak2
Nov 30, 2009 02:08 PM
wish234
Mar 4, 2009 10:14 AM
