05 ebrake doesnt work
Old Jan 21, 2015 | 11:41 AM
barticus520's Avatar
Exclamation 05 ebrake doesnt work
I changed the driver rear caliper a few years ago and the ebrake stoped working afterwards. I changed that caliper and magically it started to work again.
Now I just changed the passenger side rear caliper and now the ebrake doesnt work again, I changed it for a second caliper and still doesnt work. everything works if I adjust the cable that is underneath the arm rest but in order for the lever to engage properly I have to adjust the nut alot and then the rear brakes drag alot. I had to loosen the cable to stop the brakes from dragging and I can easily pull the handle all the way up and the ebrake will barely hold the car at idle.
I have been searching everywhere and never found an answer. please dont ask me to adjust the nut in the armrest because that is not the issue.
Old Jan 21, 2015 | 11:42 AM
The only thing I didnt do is try to use the original caliper again. I will try that when I get my car back in a few days, my fiancee borrowed it while I change her rear pads and caliper which is leaking fluid.
Old Jan 21, 2015 | 05:06 PM
Description suggests something wrong w/ rigging of e brake cables to caliper arm/cam that actuates the caliper for e-brake function. If you disassembled caliper ebrake you may have something wrong.
WinstonDouble
Jan 21, 2015 11:53 AM
barticus520
Aug 23, 2011 05:13 PM
toicy4ya
Jul 26, 2009 05:31 PM
kellysa111
Jul 12, 2009 06:10 PM
kellysa111
Jun 19, 2009 09:00 PM
