[SOLVED] '04 Accord: What is this strange clicking/ticking sound from dash...
-----UPDATE: PROBLEM FOUND..... see LAST video, still need help pls! ------
Hi All, new to forum, but have been lurking... My '04 Accord EX (135k mi) has a strange clicking/gurgling/bubbling sound coming from dash area, driver's side. It's weird, occurs at random, and sounds like its behind the speedo area. Here's a video of it (sorry, the sound is low): It's pretty pronounced sitting at a red light (prob cuz I can hear it more!) Anyone heard of/reported this before? |
When I click the vid I get a message "this video is private".
Does the sound only happen when the AC is on? |
Try the video now.
The sound happens WITH and WITHOUT the A/C on. Rather annoying and bizarre. |
I have the exact same thing! I'd love to know what that is.
On my 03 MDX and other Honda products, a frequent problem is air mix motor cycling or hunting. It makes a cyclic rattling sound which may be your problem. See following link.
Rattling Center Dash (Heater A/C Air Mix Motor) - Acura MDX Forum : Acura MDX SUV Forums good luck |
(Post 325895)
Rattling Center Dash (Heater A/C Air Mix Motor) - Acura MDX Forum : Acura MDX SUV Forums good luck When I do here this repeated "clicking/bubbling" sound, I notice I am able to make it recur/reappear when changing the temperature control setting (eg: 62-->72, etc.) Anyone else have ideas? |
Your diagnostics furthe indicate air mix motor is problem. When you adjust temp you are commanding air mix motor to change air mix to get new temp setting.
good luck |
I found the problem! This is located driver's side, below right steering column area. Whenever I adjust the temp, this moves and then the clicking ensues. Turn up your volume, you'll see what I mean....
What is this part, and does anyone know the fix? Thanks all! |
That is Air Mix Control Motor. Fix is generally replacement. The problem may be grease in the motor movement obstructing the wiper/resistance contact strips, causing intermittent contact and the hunting action you see.
Some have managed to remove the motors, clean excess lube, and re-install. However it is easy to get the gear mesh alignment wrong and motor will not "mix" correctly. The links I earlier posted discuss these issues. It doesn't look to difficult to replace, but shop manuals are notorious for ignoring interference issues that complicate under-dash repairs. Remove connector and 3 screws to release motor. I would suggest purchasing an e-manual from automanualsource.com to obtain factory drawings and procedures. good luck |
(Post 328417)
Some have managed to remove the motors, clean excess lube, and re-install. However it is easy to get the gear mesh alignment wrong and motor will not "mix" correctly. The links I earlier posted discuss these issues. It doesn't look to difficult to replace, but shop manuals are notorious for ignoring interference issues that complicate under-dash repairs. Remove connector and 3 screws to release motor. I would suggest purchasing an e-manual from automanualsource.com to obtain factory drawings and procedures. good luck Thanks Texas! 1. Do you have a recommendation for where to buy the part from? 2. Do you how to locate the part # -- or would that be included in automanualsource? |
| All times are GMT -5. The time now is 12:17 AM. |
