04 Accord - Tracking down oil leak
Working on my god daughters 04 Accord Sedan with an ongoing oil leak. Here are some details-
My plan is to remove belt and pulley and see what it looks like back there. Any suggestions would be much appeciated!
You say timing chain, so it must be the 4-cyl engine? Please confirm that.
Just to rule out something easy, check to see whether the oil filter is seated correctly. But I don't think it would spray from the pulleys that way. There's also a tensioner for the timing chain around there. Might be partly hidden under the pulley, so maybe it would throw the oil like that. |
Yes it is 4 cylinder. No leak at oil filter, checked that.
1 Attachment(s)
Unless you remove the crankshaft pulley, you may not be able to see a couple things.
#3 is a crankshaft timing sensor. #2 is a cover over the timing-chain tensioner. Either of those things would be easier to fix than the front crankshaft seal #6. |
