04 accord v6 # 4,5,6 cylinder
Old Oct 17, 2011 | 09:05 PM
leroydiabolo's Avatar
Default 04 accord v6 # 4,5,6 cylinder
I just replaced timing belt and water pump on my 04 accord. now # 4,5,6 cylinder not firing-----install 3 new coil pack----same problem-----r/r timing belt and realingn belt----car runs rough on 4, 5,6 which are located on front of the engine. any help would be appreciated
Old Oct 18, 2011 | 09:09 PM
I'm going to help you get some help by moving you to the correct forum which is where your reading this now..Have a great day..
Old Oct 18, 2011 | 09:33 PM
Was the Check Engine Light on before? Have the car scanned for any trouble codes. It may be caused by a sensor unplugged or a faulty sensor.
Old Oct 20, 2011 | 04:33 PM
found out r/s engine mount crack wide open and pull crank sensor harness-----since sensor is located behind crank sprocket.... replace sensor and repair harness----car runs beautiful......
thanks guys for the help
Chris Jameson
Feb 19, 2013 06:39 AM
Ken Boelter
Apr 13, 2010 09:55 PM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
aso432
Oct 23, 2005 10:41 PM
