Sponsored by:
Sponsored by:
'05 Accord -- Knocking under Hood, Cold Start
Old 11-11-2012, 06:18 PM
Girlie-Girll's Avatar
Default '05 Accord -- Knocking under Hood, Cold Start
I need help. I have an '05 Honda Accord EX-L 4cyl -- 67K miles
Here's the thing: At the beginning of the year, I hit the curb with my Front Right tire. I got my wheels aligned. 7 months later, I noticed that the front right tire started having 1-sided wear towards the outer edge of the wheel.
So I bought 4 new Falken tires at America's Tires, and got the alignment done at Midas because I got a "deal" for $50. BUT, the dumb nut-heads at the Midas shop aligned my car to Honda Civic alignment specs, instead of Honda Accord. Geez, how does one manage to screw up a Computerized Wheel Alignment?? Imagine letting them complete a major repair.
So, I went back to Midas the next morning to have them re-align it to Honda Accord alignment specs. They still couldn't get it straight, as they set the specs to a DX model, and I have an EX (DX specs varies a little). Anyway, the manager told me to go back to America's Tires and have them re-balance the tires because I was experiencing wheel vibration after the first (wrong) alignment. So, I got the tires re-balanced (2 tires were out of balance).
On a flat road, the car drives fairly straight. BUT, when making left turns, the steering wheel slightly tugs to the right.
The morning after the first (wrong) alignment, when I started up my car, I noticed that on a cold start, if I don't wait for my car to heat up, and I shift gear into drive or reverse, I hear a loud knocking sound on the right side under the hood (sitting inside the car), and at the same time, the steering wheel vibrates loudly like crazy. Once the car heats up after driving for awhile, the sound + steering wheel vibration goes away.
HOWEVER, after finally getting the car aligned to Accord specs., this steering wheel vibration + knocking sound DIDN'T go away. Even in the coldest temps., this has NEVER happened before.
I'm trying to rule out a few things to gauge the cost of a repair for this problem. Could it be....??
1. Piston Slap
2. Bad Ball Joints or Bushings
3. Bad Tie Rod
4. Bent Suspension Arm from hitting the curb (Would the suspension arm cause a sound like that on a cold start gear shift?)
5. Broken Engine Mount on that side of engine
6. The fact that the stupid techs. at Midas wrongly aligned my car to Civic specs. and then to Accord specs.
Any info/comments/feedback would be greatly greatly appreciated...
I'll try to post a YouTube video and link it here later..
Old 11-11-2012, 06:30 PM
I moved your thread for more responses to your question.
Old 11-12-2012, 11:06 AM
Dr. Drivability's Avatar
noise/vibration on the right side when cold or all the time now leads me to believe you have an accessory pulley/component going bad...waterpump, tensioner pulley etc...as far as the pull, try swapping the two front tires side to side to see if there is any improvement.
cerbera33101
03-15-2012 09:29 AM
Pickrng
06-22-2010 12:54 PM
lionelbob
08-23-2009 05:04 AM
dtycoon2003
08-11-2006 08:29 PM
boo623
07-09-2005 07:30 PM
Quick Reply: '05 Accord -- Knocking under Hood, Cold Start
