05 sedan fog lights not working
Old Aug 1, 2009 | 01:45 PM
05 EXL's Avatar
Default 05 sedan fog lights not working
I installed this genuine Honda kit myself last year. Has been working fine up to a month or so ago. Realized neither lights was on. So of coursed I checked the bulbs realizing it was highly unlikely both bulbs blew at the same time. Both bulbs were good. I checked the fuses and they are fine. The switch lights up as it should in the on position. Im thinking it might be one of the the two relays in the wiring harness. Just wondering if anyone else has had this problem. Thanks in advance for any help you can lend
Old Aug 4, 2009 | 02:19 PM
05 EXL's Avatar
no one? Grounds are good. im trying to think of what else I checked when I looked at it. I guess I will have to break out the wiring diagram and check to see where power stops. Im assuming at one of the two relays.
Old Aug 4, 2009 | 05:05 PM
I don't know how they are wired. You said that there is a good ground at the bulb socket. Do you have 12V on the other wire? If not, then work back to the relays.
Old Aug 5, 2009 | 11:58 AM
05 EXL's Avatar
If I remember correctly there was not. That is why I was under the assumption it was one of the relays.
csh217
Apr 30, 2013 09:03 PM
qkumbr
Sep 5, 2010 10:39 AM
TACORICAN
Mar 24, 2010 04:30 PM
accordking
May 13, 2009 07:38 PM
arunsam3000
Mar 6, 2007 01:40 PM
