06 accord crank but whont start
Hi guys
I new to this site so tnx in advance for your help. I recently change the clutch on my 06 accord i4 mt, after the job i whent to star the car and it did but i had forgot to put the coolant hose back to the rad, so i turn it of plug it back in add coolant, then restart it. I stall it trying to back up, and them it would start any more. I've been around some of the fuse check a few conection. While pulling my intake manifold to get to the clutch if rip off the knock sensor wire, that i fix after. Any suggestion?? |
Might want to check the ground cables - there is usally a main ground for the PCM on the engine block.
Is this a 4 or 6 cyl |
4 cyl.
Did you get it running again? You talked about removing the intake, did you get the main ground for the PCM (G101) back on and tight?
Yes tanx for the advice, i recheck all my ground and it was the one by the injecter that was lose. But now the check engine came and its giving me code : 122. What now?? I recheck my connection everything seem tight.
Sounds like another ground might be off. I'll see if I can find that one.
You will want to also be sure the TPS connector is fully seated. |
