06 accord crank but whont start
Old Nov 12, 2014 | 01:57 PM
450r's Avatar
Default 06 accord crank but whont start
Hi guys
I new to this site so tnx in advance for your help.
I recently change the clutch on my 06 accord i4 mt, after the job i whent to star the car and it did but i had forgot to put the coolant hose back to the rad, so i turn it of plug it back in add coolant, then restart it. I stall it trying to back up, and them it would start any more.
I've been around some of the fuse check a few conection. While pulling my intake manifold to get to the clutch if rip off the knock sensor wire, that i fix after.
Any suggestion??
Old Nov 13, 2014 | 05:46 PM
Might want to check the ground cables - there is usally a main ground for the PCM on the engine block.
Is this a 4 or 6 cyl
Old Nov 14, 2014 | 05:04 AM
450r's Avatar
4 cyl.
Old Nov 16, 2014 | 08:37 AM
Did you get it running again? You talked about removing the intake, did you get the main ground for the PCM (G101) back on and tight?
Old Nov 16, 2014 | 01:40 PM
450r's Avatar
Yes tanx for the advice, i recheck all my ground and it was the one by the injecter that was lose. But now the check engine came and its giving me code : 122. What now?? I recheck my connection everything seem tight.
Old Nov 17, 2014 | 06:36 PM
Sounds like another ground might be off. I'll see if I can find that one.
You will want to also be sure the TPS connector is fully seated.
jacco221
May 28, 2014 11:35 AM
crowcaller
Jan 1, 2013 07:46 PM
9foaccord
Nov 22, 2010 08:46 PM
dimbee
Oct 12, 2007 02:52 PM
jrparks
Sep 13, 2007 08:16 AM
