06 accord v6 puzzled
Hi I'm trying to fix my son's 06 honda accord. Suddenly the car wouldn't accelerate the blinking d light vsa and check engine all came on. We scanned codes but a bunch came up like a lot of codes not pointing to one thing making it seem that they are old or stored codes. We replaced the throttle position sensor and thr blinking d light went away but still no throttle at all in the gas pedal. Had someone look at it and they were sure it was the ecm. We replaced the ecm. Start the car still no throttle at all in pedal vsa light and check engine still on but no blinking d light. We are puzzled. The car belongs to my 17 year old kid so we are trying to figure this out bit everyone is baffled.
Please list all the codes you currently have on the scanner.
I will post all the codes I'm going to see if I can get a print out of them and upload a picture
Originally Posted by PAhonda
(Post 400964)
Originally Posted by Kcoffee
(Post 400966)
will see if I can upload a pic
It is difficult to give advise without any codes for a starting point. Please post the current codes when you can.
On the 06 accord, there is an accelerator position sensor (app sensor) that is near the passenger windshield in the engine bay. This is connected to the gas pedal inside the car. Also the throttle body has a throttle actuator (motor) and a throttle position sensor that are monitored by the engine computer. I think the OEM throttle position sensor is part of the throttle body and the entire throttle body would need replaced. Do you know which was replaced? |
(Post 400976)
I don't think a throttle position sensor can be accidentally installed where the APP sensor is located, so probably the APP sensor was replaced. Without codes, I can't tell you what needs replacing.
My best recommendation is to get a service manual that covers your accord. Automanualsource.com has a pdf you can download for $22 and is definitely worth the investment if you DIY repair this accord. |
(Post 400989)
My best recommendation is to get a service manual that covers your accord. Automanualsource.com has a pdf you can download for $22 and is definitely worth the investment if you DIY repair this accord. https://cimg0.ibsrv.net/gimg/www.hon...f87b97e133.jpg https://cimg1.ibsrv.net/gimg/www.hon...f8af149f79.jpg |
(Post 400989)
