06 Honda Accord Shakes at stop.
Old Nov 2, 2012 | 11:04 AM
hakim's Avatar
Question 06 Honda Accord Shakes at stop.
My Honda Accord 2006 have some issues, it drives fine on the road even at 80mph, but then when i stop at the light it shakes and then it shakes even more with AC on. HELP.
Old Nov 2, 2012 | 11:12 AM
May be your engine mounts. See this Honda technical service bulletin which sounds similar to what you're describing:
Honda TSB 04-024
Old Nov 4, 2012 | 02:06 PM
Talking
Honda TSB 04-024
Looks as tho he never came back in to even read your msg..makes you wonder why some guys even post anything..I'm going to go into his CP and send him a message and his PW..maybe he forgot it..lol
Ang...Your WheelBroker
Attached Thumbnails 06 Honda Accord Shakes at stop.-526512_10151278647314989_2039005446_n.jpg
Old Nov 7, 2012 | 12:48 PM
hakim's Avatar
I ordered engine mount on ebay, i got it today and i did removed the old one and mount the new one. But, i still have the same issue. Only replaced the right one though.
Old Nov 7, 2012 | 06:57 PM
What engine is in the car, 4 or 6 cyl? What is the milage on it?
An '06 should be about due, if not already, for a new set of plugs....is where I'm going.
Old Nov 8, 2012 | 02:17 PM
hakim's Avatar
It has about 73000 miles on it, w/ 4 cylinders and i just changed the plugs couple weeks ago.
Old Nov 8, 2012 | 06:45 PM
Sorry, should have asked this as well.....auto or manual trans. The auto trans 4cyl in this gen does have an "active" mount system that controls the front engine mount.
Old Nov 9, 2012 | 04:13 PM
hakim's Avatar
It automatic 4 cylinder, what is that "active" mount system, can it be fixed or it has to be replaced?
Old Nov 9, 2012 | 06:49 PM
It means there is a solenoid controls vac to the mount to help take vibrations out of the car in some situations....mostly at idle when the car is in Drive. Honda has been using this for many years....my 95 auto had it.
Do you have a volt meter and willing to do some tests. I can post the procedures or you can get a manual and follow those. A handheld vac pump is also needed, might be able to rent one?
This pic will show the location of the solenoid and the front mount which is controlled by that solenoid and the PCM.
Again, I'm trying to take what you are telling us in words and trying to come up with the next step in testing.......
Attached Thumbnails 06 Honda Accord Shakes at stop.-7th-gen-4cyl-auto-mount-control-loc.jpg
Old Nov 10, 2012 | 03:43 AM
Silver6gen's Avatar
what plugs did you put in? you NEED to put in the manufacture recommended plugs. Honda (and subie) engines don't like other plugs
