06 Rear Door not power locking/unlocking.
Old Apr 7, 2016 | 05:07 PM
Flooazz's Avatar
Default 06 Rear Door not power locking/unlocking.
2006 4dr EXL, rear driver side door.
-Does not lock or unlock with the fob remotes.
-Does not lock or unlock with the power lock switch.
-The lock functions properly when manually lifted or pressed.
-The child lock switch is not the problem.
-When manually locked, and when locking twice with the remote, the horn will sound properly.
-When manually unlocked, and when locking twice with the remote, the horn will not sound as it knows that door didn't lock.
-Fuse setup has one fuse for all doors, so that's not the problem.
-Last night I replaced the door actuator with a genuine Honda part (quite an easy task) but that did not solve the problem.
-The wiring clips inside the door panel does not seem to be a problem.
Any thoughts as to where to look next?
I do not know how to bench test the actuators.
I'm thinking of installing the old actuator on the front door (same part #) just to test if the old actuator is faulty. If it is faulty, then I'd figure that the new part I installed is also faulty.
Old Apr 7, 2016 | 06:48 PM
Dr. Drivability's Avatar
you need to make sure you have power and good ground to the actuator.
JeffN9
Jul 13, 2015 02:35 PM
stubby1962
Feb 25, 2013 06:42 PM
kentocorp
Dec 9, 2012 12:21 AM
rak007
Jan 12, 2012 11:49 AM
bsterr
Mar 2, 2010 10:23 AM
