07 accord 2.4 code 1157
Old Mar 10, 2019 | 07:38 PM
  #21
Jordan.mcmanus40's Avatar
I'm battling this same problem on 04 LX. I just bought car and believe someone has worked on it before. It was dang near finger tight when took old one out. It was densco brand, would that possibly been one from factory? Or would it have had different brand?
. I have nothing to compare it too but it doesn't look bad as far as all chalked up.
Old Mar 11, 2019 | 07:41 AM
  #22
07honjohn's Avatar
Originally Posted by Seanjordan20
Have you found the issue? If your issue does not clear then check for short/open in the signal and ground wires from PCM connector A to the sensor. If a fault is not located then the next thing will be a PCM issue.
The P1157 indicates an open/short in the wiring this is why the code is different. Usually a new O2 sensor fixed it because the issue is at sensor. There is something wrong with the wiring in the line or you have a bad sensor. Denso seems to be the only ones that work correctly on these cars but sometimes you can get a bad one. Have you gotten a replacement.
ive not found the problem yet.do you know which wires does.and the ohms or volts they put out thanks
Old Mar 15, 2019 | 10:56 AM
  #23
07honjohn's Avatar
Default 07 accord 1157 code
Well i think ive fixed the problem i replaced the the other 02 sensor right below the manifold and the throttle body together and the check engine light has not came back on in 2 days.thanks for all the help
Khai Son
Mar 14, 2012 11:32 PM
Rtherres
Jan 30, 2011 04:58 PM
will'i'am
Sep 16, 2010 01:19 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
