07 oxygen sensor code
Old Aug 10, 2015 | 11:31 AM
travrach's Avatar
These really need to be properly tested, if you had a issue with the Cat, then it will generally set a cat code-P0420. The code you are getting is slow response, are you able to monitor the sensor via a scanner?
Old Aug 11, 2015 | 06:16 AM
wolfehunter's Avatar
So what are some things that throw a "slow response" code. Could it be a faulty new O2 sensor? Been considering buying an inexpensive scanner.
Old Aug 12, 2015 | 07:40 AM
travrach's Avatar
Yes, for that code the sensor is probably the issue, but without monitoring it kinda hard to say. The other thing is, it maybe the wrong sensor...like wrong year,etc. I think I'd return it, and verify correct one.
Old Aug 12, 2015 | 01:18 PM
Turtlehead's Avatar
Just write down the Denso part number located on the side of the sensor and confirm. They may have given you the wrong one, such as one for a ULEV engine. Also, you stated you replaced both sensors on the car. Did you put them in the correct places? If the connectors are the same and the wires reach it could easily be done.
3dw1n
Jan 14, 2015 01:53 AM
jacksta
Jun 25, 2010 04:19 PM
AcidGod
Feb 24, 2009 01:44 PM
dmost30
Sep 8, 2008 12:42 AM
dmost30
