08 Accord EX-L 4 cyl Check Engine Light and VSA Light
So I have my VTC Actuator replaced by the dealer due to that cold start grinding they make. Extended warranty covered it. Thank God I got it! Grinding gone. Got the updated actuator. :D
I immediately had some slight rough idling so I call them and the tech says it still needs to relearn the idle. My immediate concern was, why didn't he perform the idle relearn procedure before I picked it up? :confused: Hmm..... So they say to drive it and it'll relearn it, so I do. That was like yesterday. Not all of a sudden my Check Engine light comes on tonight and the VSA light comes on too with the exclamation point in the triangle too! I push the VSA button and nothing. :( Hooked up my OBD II reader and got a ERR code on it. Does the 08 Accord have the OBD II system? Any ideas on what maybe going on with the lights? Thanks for any ideas/suggestions. Guess I'm gonna have to have it towed to the dealer since they are over in Johnson City, TN and I'm over the mountain in the Asheville, NC area. Around 65-70 miles away. |
Apple Tree Honda - halfway to Hendersonville? Isn't that closer?
What kind of code reader do you have? There's like 4 different data-protocols, and if your reader is older it might not read every newer car ("CAN-bus" type is probably what you need?)
I had a cheapie reader that worked fine on our 2001 Saab, but couldn't read our newer Saabs or daughter's 2013 Civic. |
Originally Posted by JimBlake
(Post 368812)
(Post 368813)
Originally Posted by dwbaily@hotmail.com
(Post 368824)
Thanks again Jim for the reply. I have a OTC Stinger Electronics model 3769 reader. Will have to check the net to see if I can find info on it. ;)
Fair enough about the dealers. My daughter was down there for a couple semesters, about 10 years ago so that's the only reason I know that dealer exists.
(Post 368829)
