08 Gas tank size
Old Oct 12, 2010 | 05:10 AM
noahlizard's Avatar
Question 08 Gas tank size
Manual ( and all else I read) says 18.5 gal,but I can put ~ 20.1 gal. What is the actual size?
Old Oct 12, 2010 | 07:31 PM
It's approximately 18.5 gallons. You may just be paying more by having the extra gas going through the pump's vapor recovery system back into the gas station's tanks.
http://www dot epa dot gov/donttopoff/
Old Oct 13, 2010 | 05:04 AM
noahlizard's Avatar
The gas can be seen going into the car!
Old Oct 13, 2010 | 10:01 AM
A vapor recovery system has holes in the sides of the nozzle so that vapors and excess gas can be returned to the station's tanks.
I have an 8th gen Accord, it has never been close to being able to be filled to 20 gallons.
Each time you do fill ups, fill the tank all the way, then divide the miles you traveled from the last time you filled up. This will give you your average mpg. Compare your mpg with any of the times you can fill to ~ 20 gallons of gas, and to Honda's published avg. mpg.
http://en dot wikipedia dot org/wiki/Vapor_recovery
Old Oct 13, 2010 | 02:42 PM
An alternative, you can fill the tank to around 18 gallons or so, and try to add more gas via gas containers (since the containers won't have a vapor recovery/return etc.).
bjr001
Nov 25, 2010 12:05 AM
play4801
Dec 11, 2006 01:31 AM
shastylz
Dec 9, 2006 05:20 PM
iridebmx33
Nov 21, 2006 08:51 PM
compassltd
Jun 9, 2006 12:03 AM
