1900rpm noise (power steering....)
Old Dec 12, 2011 | 04:23 PM
BrotherAli's Avatar
Default 1900rpm noise (power steering....)
I recently changed the timing belt on a 96 accord, after doing so I noticed some noise coming around the 1900rpm range that will pretty much remain constant if I stay there, slow down or speed up and the noise is gone.
After googling it seems this is a common issue due to a lose heat shield or cat. converter; but here is the kicker, the noise changes if I loosen or tighten the power steering belt. I was able to get the sound to be very minor/not as frequent by playing with the tension on the power steering belt but it never completly goes away.
Any ideas?
Old Dec 12, 2011 | 07:15 PM
Play with the tension on the alternator belt. Also check out the common DIY thread for a tip about changing the timing belt. It has to do with the tension pulley installation.
loki16
Aug 12, 2013 06:54 AM
darkgreen18290
Jun 25, 2013 07:51 AM
random888
May 15, 2010 08:21 PM
akennedy89
Mar 5, 2010 06:55 PM
Johnene
Jan 4, 2010 06:12 PM
