1990 accord shift lock problems
Old Jan 20, 2012 | 02:35 PM
90snowman's Avatar
Default 1990 accord shift lock problems
The key gets stuck in the ignition but when I wiggle my shifter towards Reverse
a "click" will happen by the ignition and then I can remove my key. It is my shifter that is causing the interlock system to engage. Maybe the solenoid or shifter needs adjustment? I have used the search but havent found a specific answer.
Old Jan 20, 2012 | 02:54 PM
It could be the gear position switch or the shift lock pin switch. If you have a volt meter, you may be able to do some tests on those two items. They are open/closed circuits when the shifter is in park.
rydnlow1120
11
Nov 11, 2015 05:29 PM
ICApproval
Jan 5, 2012 11:59 PM
bo bradley
Oct 3, 2011 07:23 PM
tobytigger
Oct 31, 2009 09:57 PM
thunder_x
Oct 24, 2007 10:26 AM
