1990 Accord TCU location?
Old Aug 21, 2012 | 09:33 AM
shawneehawk's Avatar
Default 1990 Accord TCU location?
Hi, first time poster here. This is in reference to my 1990 Honda Accord LX, automatic transmission. Recently, the transmission dropped into 3rd (I believe), and wouldn't come out. In reading other threads on this forum, I believe the problem to be the TCU, as I am able to disconnect the negative battery terminal for 10 seconds, then reattach. This takes care of the problem temporarily, as in 2 or 3 days with light driving. I thought the TCU was under the passenger side floorboard, where the feet would be, but all I see there is the ECU, a long rectangular unit, which was replaced in 2009 (that problem turned out to be the main relay, which I replaced myself). My mechanic said the TCU would be under the center console. So where is the TCU? Thanks in advance for any help.
Gary
Old Aug 21, 2012 | 10:20 AM
Both the ECU and TCU are under the passenger foot well.
http://techautorepairs.com/images/tcuremovesteps.jpg
Old Aug 21, 2012 | 10:34 AM
Old Aug 21, 2012 | 10:57 AM
Thanks, redbull-1. That is exactly what I am looking at. So the TCU and ECU are both under that cover, right? Good thing I didn't listen to the mechanic! I have to run for work in a few minutes, but will check it out tomorrow and get the part # off the TCU so I can get one ordered. Thanks again!
Gary
Old Aug 21, 2012 | 11:01 AM
Yes, both are located underneath that protective plate.
Old Aug 23, 2012 | 07:03 PM
So I got the TCU pulled today and looked at the part number. It is 28100-PX0-921-M1. The TCU I was thinking about replacing it with is 28100-PX4-832. It is supposed to fit a 1990 Honda Accord. Is there some way to check part compatibility?? BTW, some good info in those links above.
Thanks, Gary
Old Aug 24, 2012 | 06:56 AM
Does anyone know if the part I listed above will work, or do the part numbers have to match up exactly?
Thanks, Gary
atlsk8crewboi22
Sep 21, 2009 12:39 AM
azslayer_1
Apr 2, 2009 10:42 AM
GoJackets
Jul 26, 2008 04:59 PM
jedds92
Dec 1, 2007 12:13 AM
kornfox
Mar 29, 2007 10:48 PM
