1991 Honda Accord Fuel Pump voltage
Old Sep 23, 2009 | 08:14 AM
f18atc's Avatar
Default 1991 Honda Accord Fuel Pump voltage
Have a 1991 Honda Accord that quit running on me the other day. The engine turns over but will not fire. Fuel pump does not run with ignition on. Main relay clicks twice when ignition is on and battery voltage is at main relay harness (12.5 volts) but only 6.9 volts at fuel pump connector with relay connector jumpered and ignition on. With main relay removed and reading thru source and ground at fuel pump connector, I'm not reading "open" but about 69 ohms. Does anyone have a good wiring diagram so I can start tracing this harness to see if I have a bad ground/wiring issue. The wiring diagrams that I have show a straight connection from the main relay connector to the fuel pump, but have already found a connector hidden behind a panel in the trunk. Ant help would be greatly appreciated.
Old Sep 23, 2009 | 08:55 AM
hondadude's Avatar
You are reading the voltage drop across/through the fuel pump, if you are checking with the connector plugged up.
Unplug the connector, then see if you have full voltage at the fuel pump connector for 3 seconds when the key is turned on.
http://www.freewebs.com/hondadude/93AccPGMFIsch1.pdf
http://www.freewebs.com/hondadude/93AccPGMFIsch2.pdf
Old Sep 23, 2009 | 09:13 AM
f18atc's Avatar
This is being read with the fuel pump connector disconnected
Old Sep 23, 2009 | 09:38 AM
hondadude's Avatar
The wire harness runs down beside the drivers seat under the carpet.
You should be able to pop off the scuff guard at the bottom of the door and peel back the carpet to see it.
Old Sep 23, 2009 | 09:42 AM
f18atc's Avatar
Yeah, that's my next step. Read resistance at the fuel pump connector and start jiggling that harness until I get a "hiccup".
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
kissbally78
Jan 18, 2009 07:14 PM
doubled
Nov 3, 2008 01:41 PM
asilomar244
Feb 1, 2006 05:29 AM
