1992 accord questions
I have a 1992 honda accord lx with auto trans, how do i add atf? and how do i remove the back seat? thanks in advance
RE: 1992 accord questions
ATF is added through the dipstick entry into the trans. Pull dipstick and use a long, small-tipped funnel to pour ATF. I would suggest downloading the 91 Accord Shop Manual from www.hondahookup.comfor the seat removal procedure.
good luck |
might want to pick up a haynes manual, just for future reference...
Remember to check ATF fluid level with engine off.
To remove the rear seat, get into the crack between the back rest and bottom cushion, about 1/2 way across you'll find a 10mm bolt holding the rear of the bottom cushion. after that bolt comes out fold the bottom cushion foward; then you can easily see the way the rear cushion is held in. |
