1992 accord questions
Old Aug 3, 2007 | 06:12 PM
proads26
Default 1992 accord questions
I have a 1992 honda accord lx with auto trans, how do i add atf? and how do i remove the back seat? thanks in advance
Old Aug 3, 2007 | 08:03 PM
Default RE: 1992 accord questions
ATF is added through the dipstick entry into the trans. Pull dipstick and use a long, small-tipped funnel to pour ATF. I would suggest downloading the 91 Accord Shop Manual from www.hondahookup.comfor the seat removal procedure.
Old Aug 3, 2007 | 10:09 PM
smaglik's Avatar
might want to pick up a haynes manual, just for future reference...
Old Aug 3, 2007 | 10:16 PM
hondadude's Avatar
Remember to check ATF fluid level with engine off.
To remove the rear seat, get into the crack between the back rest and bottom cushion, about 1/2 way across you'll find a 10mm bolt holding the rear of the bottom cushion. after that bolt comes out fold the bottom cushion foward; then you can easily see the way the rear cushion is held in.
foxboysracing
Aug 9, 2015 05:34 AM
LenoraaF
Dec 7, 2013 06:10 PM
ephraim.johnson
Jan 21, 2010 07:40 AM
mattv
Nov 29, 2007 03:47 PM
ElectricTwilight
Jan 24, 2005 01:44 PM
