1992 accord rev up n down
i have a 1992 accord that i just did a timing belt n water pump on. the head was sent to a shop n now the motor is put back together , i check the valv to see if they it was bent every thing was going good untill i started the car , the motor started to rev up n down, so i check timing,distrib,n coolant to see if it can b bleeded out , that did not help.can some one help
Vacuum leaks?
You "check the valv"...? Which valve? Does the throttle close completely? Throttle body clean? Throttle cable goes slack? |
i will go over n recheck wat you have said,thank jim,n will get back
