1992 accord rev up n down
Old Jun 2, 2010 | 11:36 PM
nickel904's Avatar
Default 1992 accord rev up n down
i have a 1992 accord that i just did a timing belt n water pump on. the head was sent to a shop n now the motor is put back together , i check the valv to see if they it was bent every thing was going good untill i started the car , the motor started to rev up n down, so i check timing,distrib,n coolant to see if it can b bleeded out , that did not help.can some one help
Old Jun 3, 2010 | 06:50 AM
Vacuum leaks?
You "check the valv"...? Which valve?
Does the throttle close completely? Throttle body clean? Throttle cable goes slack?
Old Jun 3, 2010 | 01:23 PM
nickel904's Avatar
i will go over n recheck wat you have said,thank jim,n will get back
mdowen
Mar 16, 2012 01:20 PM
felpz420
Jun 14, 2011 07:10 PM
vdub90vw
Apr 1, 2011 07:47 PM
ezekielguy86
May 24, 2009 04:43 PM
adema222
Mar 20, 2008 06:24 PM
