1993 accord 4Dr and I have a valve question
Old Nov 8, 2007 | 07:57 AM
mikeson
Default 1993 accord 4Dr and I have a valve question
Hi guys,
I want to say hi first.
Anyway, I have 1993 accord and after I replace a distributor, I have some strange knocking noise.
The noise comming fro a little valve like thing on a firewall.
(Red circle from a picture)
So I replace the valve like thing( I don't know the name), but still when it's idle or turn on signal or turn on headlight, it has 'Tek, Tek Tek,..' like noise.
What should I replace? and what is a reason it has noise?
Thank you guys.
By the way, picture is from 'http://users.adelphia.net/~hagakure962/' this guys.
Old Nov 8, 2007 | 12:22 PM
sir_nasty's Avatar
Default RE: 1993 accord 4Dr and I have a valve question
are you sure it's not just lifter rattle? or a timing issue?
Old Nov 8, 2007 | 12:41 PM
mikeson
Yes, when the car has tick, tick noise, I touch that valve thing and it knock and knock from inside.(it's very difficult to explain but I could feel the knocking when I touch the valve thing)
And I have changed the valve thing, but still it has knocking noise.
Old Nov 8, 2007 | 01:25 PM
sir_nasty's Avatar
It sounds more like out of adjustment valves, low oil or mis-timed. Did you double check your timing when you did the distributor change? When was the last time you did a valve adjustment?
Old Nov 8, 2007 | 01:31 PM
mikeson
it was 2 weeks ago. and yes, after I changed the distributor, the noise started.
I gotta re check the timming.
By the way, what is the name of that black valve thing? the noise is comming fro that black thing.(knock, knock knock,..like)
Thank you guys.
Old Nov 9, 2007 | 01:20 AM
2POINTautO's Avatar
Vacuum hose and electrical wiring, I do not see a MAP sensor on the manifold, is this the old style, firewall mounted MAP sensor, how many wires, 3?
If its 2 wires, then I would say it the idle up solenoid for when the AC is turned on or during sharp turns to idle the engine up to give added power steering force.
Unplug it if it is 2 wires, there should be no drivability problems with AC off.
Old Nov 9, 2007 | 11:49 AM
Automatic tranny? Maybe it's the control solenoid that supplies vacuum to the rear engine mount?
Or... The EVAP purge valve should open/close repeatedly when the engine's idling.
Where do the vacuum hoses go?
Old Nov 9, 2007 | 04:29 PM
mikeson
it has 2 wires and 2 air hoses connected.
I'll post a picture later on.
thanks
Old Nov 9, 2007 | 06:17 PM
mikeson
hi,
I took a picture of the valve thing.( I replace this and still have teck teck teck,...like noise.)
so how can I fix the noise?
thanks guy
Old Nov 9, 2007 | 08:05 PM
2POINTautO's Avatar
Can you take pics of where the hoses go please.
