1993 Accord Driver's Power Window
Old Apr 8, 2013 | 11:50 AM
trueno86's Avatar
Default 1993 Accord Driver's Power Window
Hi,
I have a 1993 honda accord station wagon and recently the driver's window intermittently stopped going up. I suspected that it was the switch, so I cleaned the assembly and got most of the black gunk out of it. This failed to help the problem, so I took the window motor assembly out and that relieved the stress of the window, however it only worked intermittently. From there I tested the voltage coming from the connector to the window (red-blue and red-yellow). When the window switch is pushed down it is -11.24 volts, however when pushed up it it can be within the range of 1-2 volts.
I am out of ideas of what is going wrong, unless the drivers power window control box is broken. Please advise what I should do next. Thanks!
Old Apr 8, 2013 | 11:58 AM
A high resistance is sapping the voltage transmitted to the motor. Switch seems likely culprit despite cleaning. Did you disasemble switches and clean contacts?
Suggest trying to swap a switch from another position to driver's position to see if that fixes problem.
Old Apr 8, 2013 | 01:54 PM
trueno86's Avatar
I fixed the problem. After 20 years, there was more gunk in the thing than i had expected. I re cleaned the contacts that the window works great now. Thanks for your help.
JayKranz
Apr 7, 2014 04:33 PM
jza240sx
Apr 30, 2013 04:14 PM
banastasio
Jul 23, 2011 08:49 PM
jmalek
Feb 24, 2009 11:45 AM
mmazb3
Nov 26, 2007 03:16 PM
