Driver's side power window stopped working
Old Feb 20, 2009 | 09:45 PM
jmalek's Avatar
Default Driver's side power window stopped working
The window is part way down, but won't move in either direction. The other windows still work OK. Any ideas on what might be the problem?
Is there a way to manually close the window?
1990 LX
Old Feb 21, 2009 | 12:40 PM
jmalek's Avatar
The #30 fuse is intact, so I assume it is either the motor or the regulator. I see that Advance sells a motor+regulator assembly which I suppose might be the best option on a car this old(?). Does anyone have experience with replacing these two components? Are they fairly easy to access once the door trim is removed, or am I better off taking it to a shop?
Old Feb 21, 2009 | 11:21 PM
Flatline1121's Avatar
i have a similar problem with my 91. mine will go an inch down then stop. but goes back up.
I believe the motor/regulator assembly isn't hard to replace. the regulator unbolts from the window and comes down to unbolt from the door. The motor shouldn't be complicated either.
Then reverse to put back.
Old Feb 22, 2009 | 10:03 PM
Carebear_ehs89's Avatar
this can be tricky to get the part out of the door fram. be carefull not to pinch your fingers and be patient slow ant think it thru as you go
Old Feb 23, 2009 | 04:34 AM
Jcaleno's Avatar
Hi, when u finally fix the problem, please post back the step by step process. I can already tell i'm going to need it at some point on my 93'
Old Feb 23, 2009 | 07:51 AM
bigdawg74's Avatar
same here...
Old Feb 24, 2009 | 11:45 AM
deserthonda's Avatar
don't jump the gun and start replacing parts,, you need to diagnose, it could also be a bad switch,sometimes the contacts in the switch get corroded and window will stop working..
so once door panel is off, see if you are getting power at the window motor ,,
if no power switch or wiring could be the issue ,,if you get power most likely motor is issue,,
MyFirstAccord
Sep 7, 2012 11:04 AM
kyle94481
Aug 3, 2011 07:02 PM
Buktheng
Dec 6, 2007 05:49 PM
aceracer__
Jul 19, 2006 04:04 AM
