1993 Accord lx front wheel stud replacement
Old Feb 23, 2012 | 05:30 PM
As long as the wheels really do fit, all you may need are wheel hub centric rings.
Old Feb 24, 2012 | 06:23 AM
buhhda05's Avatar
Redbull, could u be more specific in what you are talking about? That isnt a tem i have ever heard before. The rims slid right on my bolt pattern just fine. But when i tightened the nuts, it almost seemedd that the nuts dug into the rims a little bit before they got tight.
Old Feb 24, 2012 | 10:00 AM
crispin's Avatar
you are using the wrong lugnuts.
You should not be using acorn style nuts on those wheels.
That is dangerous.
Old Feb 24, 2012 | 10:55 AM
These links have descriptions of hub centric rings, there are more:
http://www.prestigewheel.com/Catalog/HubRings66_67.pdf
Why Hub Centric Rings? - HubCentric-Rings.com
How to install Hub Centric Rings (Benefits explained) - YouTube
The hub centric rings are necessary if you have a gap.
But, like Crispin stated, you need to use the correct lugs. So, your problem could be one or both (i.e., hub centric ring needed, and/or correct lug nuts).
Old Feb 25, 2012 | 07:10 AM
buhhda05's Avatar
Thank you redbull for all the info. I broke down and took my car to Firestone and they broke the bad news to me. Apparently the rims i put on the car dont have a big enough opening in the center for them to slide over my hub. Something i wish I could have seen, but you will have that. So its back to the 17s for me. Crispin, thanks for the tip on the nuts, i will replace those as well. I am forever glad I signed up for this forum, cause you guys are on the money with the information u have givin me. THANKS TO ALL!!
Old Feb 25, 2012 | 08:42 AM
crispin's Avatar
Well if you want to run those wheels you can.
Take an angle grinder to the back of the wheel where the HUB opening is and enlarge the area some.
I have done this before and it works fine.
You want to check and tighten the lug nuts every 100 miles or so a few times but after that you will be fine.
Millions and Millions of cars drive down the road without hub-centric wheels everyday with no problems.
Old Feb 28, 2012 | 08:23 AM
  #17
imdawrlus
Mar 17, 2012 09:20 AM
adonus348
Nov 30, 2011 11:49 AM
mrmiller99
Sep 22, 2011 07:21 PM
upintheclouds90
Jun 25, 2011 02:17 PM
Mike 68
Dec 19, 2008 10:33 AM
