1993 fuel pump
ok guys car quit today yep ive got spark yep timing belt is intact but no fuel to the fuel rail and none to the tank side of the filter and its all good question is .. in my chiltions manual i have it says i can access the fuel pump in the luggage area by removing the carpet well we know the trunk to be the luggage area and we also know the tank isnt under the trunk soooo can we get to the fuel pump in the rear floor board to change it ??? due the the fact that my tank is dam near full im looking for away around that .. thanks in advance for the input
RE: 1993 fuel pump
Before changing out the fuel pump, I would make sure that you are getting power to the pump. I would get at least a haynes manual to help troubleshoot or download a shop manual from www.hondahookup.com.
If you have to change out the fuel pump, you are going to have to drop the gas tank to change it. |
RE: 1993 fuel pump
I totally agree with PAHONDA.......
make sure you get power AND ground at the fuel pump wires there is an access cover where you can get and test the wires .. if you do and still get no gas , most likely you got a bad fuel pump,, if you do not,,,, i would chk the MAIN relay .. also you might want to chk the fuel filter to make sure it is not totally pluggeed ,, but if you need to replace the pump I am afraid the tank has to come down |
RE: 1993 fuel pump
thanks guys i pulled up the carpet and where the back seat meets the trunk you can change the pump from there its been done once before..
but i will make sure i have power there at the plug i beleve its the yellow wire that should be hot ,, |
RE: 1993 fuel pump
ORIGINAL: indianbullet thanks guys i pulled up the carpet and where the back seat meets the trunk you can change the pump from there its been done once before.. , |
RE: 1993 fuel pump
I'm also pretty sure the tank has to come out to replace the pump. |
RE: 1993 fuel pump
Check for power to the fuel pump before replacing fuel pump. It can be tricky to check as the power is only available w/ keyswitch turned to ON for about 3 secs w/o the engine engaged before ECU cut's off ground to Main Fuel Relay and disables power. This is probably a safety feature to stop fuel pump running after an accident. You will need to have some help or rig a tell-tale light on a long lead back to the pax compartment. That's what I did recently to finally catch that power was available and pump was not running.
good luck I was working on a 94 but there was no access to fuel pump, although there was access to the fuel gauge sensor assy. If there is access it should be on the driver's side in the trunk just above the spare tire well. I posted details in a thread I started recently. Search should find it. good luck |
RE: 1993 fuel pump
yep l
