1993 No Start, Fuel Pump seems ok
Old Oct 31, 2008 | 10:34 AM
MA93Accord's Avatar
Default 1993 No Start, Fuel Pump seems ok
So I have a 93 dx, and while driving the other night (cold weather, heat was on) it just died at a stop sign. I Put my ear up to the gas tank door at the time, and Im fairly confident the pump runs when the key is turned. Now I heard about alot of Main relay issues, but if the pump is running, that wouldnt be the relay right? The engine just cranks n cranks. Odd too because it came out of no where. Thanks for any input.
Old Oct 31, 2008 | 10:48 AM
finch13's Avatar
Default RE: 1993 No Start, Fuel Pump seems ok
Next thing to check is if you have spark... check the DIY section.
Old Oct 31, 2008 | 11:13 AM
MA93Accord's Avatar
Yeah, gonna do so, and will post what I find.
Old Nov 2, 2008 | 01:26 PM
MA93Accord's Avatar
Ok so no spark, tested a plug on 3 diff grounds n saw nothing, which would make more sense as to why is just instantly died.
Old Nov 2, 2008 | 01:37 PM
finch13's Avatar
What you can try is sanding the cap and rotor contacts in the distributor and see if it'll start up. Other things to check are the cap and coil and if power is getting to the distributor, instructions can be found in the DIY on the main HAF page.
Old Nov 2, 2008 | 03:11 PM
MA93Accord's Avatar
Well everything seemed ok, except the test for the Igniter. I hooked up a test light to the injector and got a blinking light, which according to some paper work i pulled up for Honda/Acura Ignition Trouble Shooting, signaled a bad igniter. Now I dont know much about them, but can a bad igniter mean no spark?
Ill most likely run some more test tomorrow, Id rather hang myself than buy a part thinkin its the one, only to be wrong. But then again, I dont wanna have it towed to the shop, only to replace the part that I knew was broken.
Old Nov 2, 2008 | 03:42 PM
MA93Accord's Avatar
I didnt even look, but is it possible The timing belt is toast?
Old Nov 2, 2008 | 03:48 PM
finch13's Avatar
If your timing belt snapped, you would have heard colossal damage being done to your engine. If the timing belt slipped a few teeth it would've ran poorly, not die.
We've already figured out you don't have spark, signs point to the igniter being toast. Might as well head to the junkyard and pick up a new distributor...
Old Nov 2, 2008 | 04:03 PM
MA93Accord's Avatar
I c, and if I dont have the time or means to swap a distributor?
Old Nov 2, 2008 | 04:07 PM
finch13's Avatar
Do you have 30 minutes? Do you have a 12mm socket and 6" extension?
I dunno what else to tell you... park the car and not drive it until it gets fixed?
