1994 accord speedo not workin
hello
i joined this form because i need help i know there are other posts here about the subject but i cant find my answer so it all started with the speedometer working when it felt like doing so, the it just got stock on 20 every time i cranked the car i replaced the vvs still the same went to junk yard grab the hole speedometer unit and replaced the board that is on the back of the speedometer now it is on zero all the time everything works but my damn speedometer check the drive unit i can see it spinning the shaft that gose under the sensor. :shrug: i dont know what to do now also would it cuz my vtech to not work? pleeeeees help me:hammer::hammer::hammer::hammer::hammer::hammer: :hammer: |
If your cruise control worked the whole time, then the VSS was always working properly. Is your cruise control working properly?
The speedometer stuck at 19 mph is the same problem I had on my 95 accord. You may have to check your installation of the board on the back of the speedometer. Also inspect where the speedometer makes connections to the main cluster board. |
i have after market steering wheel and my curse control in not hooked up no more
any body?????
Have you checked for engine codes?
If trip odometer is working the VSS is working. If not, you may have a wiring fault interrupting the VSS signal. You will need to trace wiring integrity (closed or open circuit) from VSS to gauge panel.
good luck |
i got it fixed i had the wrong connector on the vss i must have accidentally hooked it up wrong when i did the swap but the board on the back of the speedometer was also bad so i fixed it
