1994 accord speedo not workin
Old Dec 31, 2015 | 05:18 PM
1994accordwithh22a's Avatar
Post 1994 accord speedo not workin
hello
i joined this form because i need help i know there are other posts here about the subject but i cant find my answer
so it all started with the speedometer working when it felt like doing so, the it just got stock on 20 every time i cranked the car
i replaced the vvs still the same went to junk yard grab the hole speedometer unit and replaced the board that is on the back of the
speedometer now it is on zero all the time everything works but my damn speedometer check the drive unit i can see it spinning the shaft
that gose under the sensor. i dont know what to do now also would it cuz my vtech to not work? pleeeeees help me
Old Dec 31, 2015 | 05:29 PM
If your cruise control worked the whole time, then the VSS was always working properly. Is your cruise control working properly?
The speedometer stuck at 19 mph is the same problem I had on my 95 accord.
You may have to check your installation of the board on the back of the speedometer. Also inspect where the speedometer makes connections to the main cluster board.
Old Dec 31, 2015 | 05:42 PM
i have after market steering wheel and my curse control in not hooked up no more
Old Dec 31, 2015 | 06:01 PM
any body?????
Old Dec 31, 2015 | 06:10 PM
Have you checked for engine codes?
Old Jan 1, 2016 | 08:01 AM
If trip odometer is working the VSS is working. If not, you may have a wiring fault interrupting the VSS signal. You will need to trace wiring integrity (closed or open circuit) from VSS to gauge panel.
Old Jan 2, 2016 | 12:48 AM
i got it fixed i had the wrong connector on the vss i must have accidentally hooked it up wrong when i did the swap but the board on the back of the speedometer was also bad so i fixed it
j_may
May 23, 2013 03:30 PM
MoDawG
Dec 10, 2009 07:00 AM
wtony
May 24, 2008 07:47 PM
nafango2
Dec 14, 2007 11:52 PM
94Jdmh22accord
Jun 3, 2007 11:18 PM
